load question
Steve7155
Student
Nov 29, 2023
1
Would a 240V, 20 amp circuit, handle 4000 watts? Would this be code?
I dont know anything about electrical but this seems like it could just be a V=I*R and P=V*I solution here.
By code, 20 Amps x 80% = 16 Amps max allowable.
16 Amps x 240 Volts = 3840 Watts max.
If you use a 100% rated breaker the max Watts is 4800 Watts.
Good luck finding a 20 Amp breaker rated for 100%.
Ohm's law
Not just a good idea;
It's the LAW!
