Equivalent Deflection Lab Test
Struct123ure
CA
In reinforced concrete flat plate buildings we design the deflection for L/360. This would be the deflection at the mid point between supports of a continuous slab.
I am testing a scaled down version of the slab, and it is loaded with a point load. How would I compare the deflection values? I could extend the tangent to the centre point? But I am not sure if that would be “accurate” enough.
I know that in reinforced concrete deflection calculations on their own aren’t “exact” based on reality.
Just shooting from the hip...
Your test setup is an upside down, simply supported beam. Since deflection is measured at the load location, I'd ignore any beam beyond the load location. You should be able to back out an equivalent EI (using deflection = P*L/48EI) for the concrete based on your measured deflection, the applied load (and doubling it for the deflection calc b/c the rxn at the middle should be double the load cylinders), and L is the distance between your point loads.
Using your computed EI's for your different load levels, you could then re-run the continuous beam analysis and see how actual EI values change the deflections you had calculated previously.
If I misunderstood what you're going for, I apologize in advance.
Agree with above. You can't directly compare deflections. The boundary conditions are different. If the beam cross sections are the same then you can back out an EI and use that in beam theory to calculate deflection in the actual case. If the cross sections are different, then you have a more complicated analysis task ahead.
