Hansac
- Dec 6, 2006
- 41
This original post (thread725-19716) refers.
Backing gas is an NEV in ASME IX for GTAW, so changing the backing gas from Argon to Nitrogren does not trigger the requalification of the PQR (but of course, welders cannot change WPS by themselves, WPS can be edited by Welding Engineer without requalifying the PQR if NEV is involved).
Secondly, N2 is an inert gas that does not react with the molten root of the weldment. Please be reminded, this is "BACKING GAS" and not used as "shielding gas" which actually would be in contact with the GTAW weld plasma arc.
A number of papers I came across do promote the use of N2 as backing gas for DSS, as well as for shielding gas in DSS/Super Duplex.
Thank you everyone in advance for your responses.
