Reboiled Stripper
MHamza37
Chemical
Dec 3, 2023
6
Greetings,
I want to confirm that how do we calculate for the material and energy balance across the reboiled stripper. Either we proceed same as the distillation column i.e we set the bottoms and distillate purity for the high and low keys and then finding the condenser and reboiler duty or there is something else.
Moreover, I want to confirm that can I assume that one of the component is 100% stripped of the system in reboiled stripper ( if there is huge boiling point and volatility difference )
Thank You very much !
