Saint Jerome
Student
Hi all...
I have a business provide soundproof meeting pods for numerous applications, and we have been trying to overcome an issue with airflow in the pods for some time. The pods have 750RPM fans which generate an airflow which is not quite adequate and has input (supply and return doesn't really apply) ducts in the ceiling with air being pushed into the pod. The walls have internal vents for output air (baffled within the walls) to exit outside top.
We thought it made good sense to ramp up the fans to 900RPM which generate 50% more airflow (and not a lot more noise) and this appeared to work OK.
However, over time, these 900RPM fans are all failing, and the actual airflow is NOT much greater than the older 750RPM fans. In fact, we measure airflow under the ceiling input vents and this increases dramatically (30%) when the door is open, but drops back when door is closed.
I suspect we are seeing an impact from output vents being too small, but this is causing back pressure on the fans, ultimately killing them!
Worse still, it might be that the additional input airflow is causing some sort of interference (turbulence) which is actively reducing airflow with the 900RPM fans to LESS than the original 750RPM fans.
I know this is light on with the technical aspects, but can anyone comment on this situation?
