milkshakelake
I think I know how to do this but I need a quick sanity check.
I have 2 wood stories supported on concrete piers, while the rest of the building is supported on typical spread footings, due to sloped grade. For the area supported on piers, my initial thought is that I'd need concrete or steel beams to support the overhang. Is that correct? The reason I'm thinking this way is that I don't think I'll be able to get a massive timber or LVL beam there to work, and the discontinuity in vertical stiffness means that the beams have to be designed for seismic overstrength.
