Engineers,
Is there any special method to compute settlement on on eccentrically loaded foundations?.
There are many references about considerations for computing bearing capacity but nothing related to settlement.
I have a square footing subjected to lateral force and moments in both X and Y directions. At the same time there is vertical load.
I have seen scenarios in which the moments and lateral loads are ignored and only consider vertical load (P). Then, with that pressure (P/A), if it results in settlement < 1 inch, the recommended bearing capacity is P/A. I am not sure if this is correct. I think at some point lateral loads and moments should play a role.
