azri_muin
- Jan 1, 2024
- 2
Hi guys,
I have some curiosity in defining pin connection, what is the best approach to define the pin connection where the pin is used to connect between two eyes, but both will be locked at both side.
(both side similar, locked with locking plate).
my question is, should we use gap contact or RBE2? and if we use gap contact, do we need to beam/bar release or constraint the nodes at the end of both pin?
Thank you in advance for your insight.
Beste regards,
Azri
Beste regards,
Azri
