mohalielectric
Industrial
- Jan 6, 2024
- 1
Low voltage high frequency motors:
I am into repairing of 3HP un-balanced vibrators, working on 48 volts 3phase 150 Hz frequency.
At times the motor that is drawing around 20 amps, after about 3 months suddenly starts drawing 80 amps current. If we remove the unbalance weights,
no load current is 9 amps and on restarting with counter weights, current is 90 amps. What could be the reason
