Algirdas13
- May 27, 2023
- 36
Hey everyone,
Currently I'm searching for best approach regarding the design of water cooled wall. I'm wondering maybe someone has encountered such structure/design? The main question for which I'm looking answer for is how to properly prepare design so that the inner and outer walls could be connected (welded) together by the same stiffening plates (in picture bellow - plates with round cutouts). I have an idea of trying to use U shape bent sheets with cut outs (example attached bellow), but such approach wouldn't look that well from outside. The walls will be applied only by hydrostatic pressure, for this reason no stay tubes are required. The gap between inner and outer wall gonna be around 80 mm. I will appreciate any insights and suggestions.
Thanks in advance!
Thanks in advance!
