Krsl
Student
- Dec 17, 2023
- 3
Hi all experienced engineers! I have a basic question for you. I am a recently graduated structural engineering student who has just started a job. I have given a structural analysis and design task. I have to design a warehouse in high seismic zone which has shear walls and moment frames to resist lateral load. The joist girders are K series and structure will have HSS columns. So, this my thinking of how should I proceed. Please provide suggestions if there is better way to do it. Here are the steps that I am thinking.
1) Find the loads by hand calc/spreadsheet.
2) Determine the member sizes based on preliminary hand calculations (i.e. from 1).
3) Model the structure in analysis software (which will be SAP in my case) and let the software do the design and analysis. Here is one confusion I have. I am thinking of modeling the joist's complex geometry based on the manufacturer (let's say Vulcraft for now). Do you guys also do the same?
4) Check if any structural members are failing or not?
5) Finalize the members if everything looks okay and don't forget to check drift limits.
