Detailing of concrete structures.
Sangeen
1
I designed my building with ETABS and i got the values of reinforcement in column and beam and now i want to do detailing so according which section of ACI 318-14 should i do detailing. I need a systematic and detailed answer plz. I am a new user.
I think you would be assisted greatly with these two things:
1. ACI Detailing Manual
2. A good mentor - experienced engineer who can walk you through things.
Before you start anything, you should know the code requirements!
JAE and rapt are correct. You haven't designed anything, you have used a computer to analyze a building structure and spit out some results. Now comes the design.
