AWS D1.1 weld structure linear dimensional tolerance
pavvpk
11
I was wondering what is typical weld structure linear tolerance as per AWS D1.1?
I can see some dimensional tolerance in Section 5.22 but I dont see anything specific about linear dimensions just like ISO (ISO-13920) specifies.
I was wondering what would be typical linear dimension tolerance specified by AWS D1.1, lets say between 0-1000mm; 1000-2000mm, etc
Pkpavv.
I suppose ASME IX has something about this.
AWS D1.1 is often used with a design/construction code like the AISC Steel Construction Manual. You would fine tolerances for fabrication and erection in the applicable construction code.
Best regards - Al
