Equivalent ASME B31.4 in EU
Cesarin2508
5
Hi Everyone,
I am working in a French project and I would like to know what the EU standard equivalent to ASME B31.4. This project is about slurry concentrate pipeline.
Thanks in advance.
Cesar
Perhaps EN 14161?
Huub
- You never get what you expect, you only get what you inspect.
Yup.
EN 14161 covers all pipelines except natural gas.
It is basically identical to ISO 13623.
Quite a nice code to use as it leaves a lot up to the designer.
You will not have an issue if you're familiar with b31.4 as it uses a lot of that code as the base mark.
Just be aware kid need to add manufacturing tolerance to the wt calc. But otherwise pretty similar.
Hi XL83NL & LittleInch,
Thanks for your answers.
Best regards,
Cesar
