VasileVlas
- Jun 23, 2023
- 2
Hello folks, I have an issue with Catia, tried to search on google and can't find a solution, so decided to try my luck with a new thread. In my current company, we are changing default font for the drawing. The issue is, that when creating and angle dimension, the numbers use our own font (defined in standard) but degree symbol stays default (in our case MonoSpac821 font). Please see the picture. This does not look good. Does anyone know, how to change the degree symbol used in angle dimension type? I also tried to change the engineering symbols font for degree symbol in standard, but looks like angle dimension is not using symbol from there. Thank you for the help.
