alok_singh
Automotive
- Mar 7, 2024
- 12
I have only lately begun to use Adams car. It contains a simulation named Roll & Vertical Force/Length that is under suspension analysis. After reading the documentation (A roll and vertical force analysis sweeps the roll angle while holding the total vertical force constant. The total vertical force is the sum of the vertical forces on the left and right wheels. You can specify the total vertical force used by the left and right actuators to move the wheels). I was unable to understand the physical significance of this analysis as compared to opposite and parallel wheel travel.
