maranep
Geotechnical
- Aug 22, 2019
- 3
I am doing an evaluation of the existing rail steel bridge for drilling rig movement. Because it is required to cross the bridge and do some secant drilling for the shoring wall. The client provides tight spacing/urban environment and no other access to transport the rig. It is a 1968 old steel bridge and grider is designed for e80 loading. I am planning to use an 8-axle truck with a trailer to transport the rig. From the old drawing, I got the max. moment(grider) for the LL, 3500 kipsft(4745 kNm), based on the truck axle load and configuration, Max. bending moment is calculated for the bridge span (8m). it is about 750 kNM. looks like it is safe to use the bridge for transport. Am I missing something to check? Thanks.
