MarcinBookowski
Industrial
- Mar 12, 2024
- 2
Hello.
I have a question about installation a three way valve in piping system. Three way valve has a one inlet and two outlets. It is not mixing valve.
The flow of media through such a valve is through an input and an output. One output is closed. What if the piping of the installation is built in such a way that the second output also receives the media. Physically, the two fluids do not mix because the valve is only open in one direction. Basically, the media (blue) flows unnecessary into the blind section of the pipe.
I wonder what this looks like from a technoligical point of view. Is it acceptable for the second outlet, basically the valve body, to be filled with media from another pipe? Does such a design guarantee the cleanliness and microbiology of the installation during production, for example, in the dairy industry?
