arankin1983
Agricultural
- Mar 18, 2024
- 1
Hi Guys, Im completely new on this so really hope you can help.
I need to produce a cantilever type racking for inside a shipping container of mine that will be situated in a level concrete yard. The plan is to have them fitted tight into the top corner of the container and out at the bottom by around 200mm so that they are effectively wedged into place and the tilt will help prevent goods falling forward. There will be a single heavy screw through the bottom of each foot just to ensure they are held in the correct position, the racks will be along the full length of the container at 1000mm spacing. I have calculated that the maximum each individual shelf would be required to carry is 144kg, spacing between shelves will be approx 330mm so 7 shelves per upright (6 with load) therefore each rack upright max load would be around 870kg
Can anyone advise the weight of box section would be required to safely carry this load? I was planning on using 100mm x 50mm box section
