Hi, I am designing a plastic container for a nasal inhaler. The container has three parts and needs to be airtight. The problem is that I cannot decide which type of ISO fit grade I have to use between mating parts, such as H7g7, H7h7 or H7k6 fit grade, etc. The material will be HDPE, and the typical wall thickness is around 1.2mm to 1.5 mm.
Thanks for your time,
Regards.
Regards.
