Pressure Testing Help/Recommendations
elopez
8
Hi All,
I am looking to set up a pressure test for a product that I manufacture. For all intents and purposes, the product is a seam welded container. Essentially, the test would consist of attaching compressed air to the product and increasing the internal pressure until failure. I want to be able to get an ultimate pressure at failure. I have also noticed that the rate at which air is introduced to the container greatly affects the ultimate strength of the seal. The goal is to have a consistent and repeatable test that I can perform regularly to check weld integrity.
I have looked into pressure regulators as well as max pressure gauges but can't seem to easily find what I am looking for. Failure usually occurs between 5-25 psi, so I would require a fairly precise instrument with some granularity. Most of the gauges and regulators I am finding are 1-100 psi or 1-300 psi which is overkill for what I am trying to accomplish.
Am I in the right direction, and I should just keep looking? Would greatly appreciate being pointed in the right direction.
For tests to failure you should do hydrostatic testing, not pneumatic.
Unless your thing is really small.
Stay safe and perform hydraulic test!
I have in mind the passing of a mechanic performing compressed air test on a HX.
Pierre
For that amount of pressure I'd consider a cylinder pressed down by a weight to reach to various test pressures. Maybe have a sliding weight on an arm that to adjust cylinder force like an old-school pressurized grease cup.
Thanks for the information all. I will look into it further!
Hydrostatic testing for pressure testing. Pneumatic testing for leakage-testing (which I assume you need to perform as well due to checking the weld integrity).
For leakage-testing: At those low pressures I would recommend using 8-16 bar (116-232 psi) inlet pressures (if using cylinder/ cylinder bundle) - or a constant line pressure of 6 bar (87 psi) (typical output for some air compressors - remember oil filter if you need that) attached to a pressure regulator with a maximum working pressure of around 3 bar (44 psi) and with a high resolution to allow for fine tuning of the workin pressure (your test pressure).
