mtomechanical
Student
- Mar 29, 2024
- 1
Hi Everyone,
Recently we had a failure on a motor shaft (Photos attached of both the shaft end in motor and the rest of the shaft from the coupling side)
The shaft is connected horizontally parallel to the pump via Jaw Coupling (Photos Attached of Jaw Coupling Found to be Broken)
After the failure, we confirmed both motor shaft and pump shaft are rotating freely.
Some info about the shaft is:
Speed = 1490 RPM
Shaft Diameter = 80 mm
This pump is used to transfer Thermanol 66 (Heat Transfer Fluid). When the motor shaft broke, the vapours of this liquid caught fire immediately and caused a explosion in the pump area.
I am still trying to do RCA/FMEA/Report for broken motor shaft. Kindly share your views regarding the following incident (especially regarding the type of failure that resulted in shaft failure). I would really appreciate your help.
Speed = 1490 RPM
These two above photos show the condition of shaft failure from the motor side
These two above photos show the condition of shaft failure from the coupling side (pump side)
The above photo shows that after the shaft failure coupling broke and hit the Steam Generator equipment next to it.
The left side photo shows the coupling from pump side (Female Side) and the right side photo shows the coupling from motor side (Male Side).
