How to perform a honeycomb structural verification?
Mijail
Aerospace
AR
I'm participating as analyst in a project to develop an spacecraft structure. The structure is made of CFRP-Aluminum honeycomb sandwich panels. Since it is a medium size spacecraft the model is complex and therefor the panels are modeled with 2D laminates (one ply for internal facing, one for the core and one for the external facing). In the case of the honeycomb I’m struggling to do the verification since the strength values to be evaluated are the out of plane shear stresses (13 and 23) but the 2D model can not provide them. How can I overcome this?
Thanks in advance!!
Bruhn has analysis of honeycomb panels. I'm sure NACA, NASA, USAF, etc (ESDU?) also do. there are probably dedicated texts as well, probably for your specific application.
A google for "analysis of spacecraft honeycomb sandwich panels" returned many promising hits.
Hexcel has a series of excellent engineering manuals. I found them still on their website a couple of years ago - you might find them still there.
Typically, use core shear strength alone for all out-of-plane shear stress. It ignores the shear strength of the facing, but since they will bend and deform with much less stiffness than the core, that's not unreasonable to ignore them.
Ah, what FEM code and element type are you using?
2D shell elements can output thru thickness shear stresses (as far back as 40 years ago).
Is this for the spacecraft... or for the launch vehicle/fairings? Huge difference and one You seem a bit unprepared to deal with.
Launch/throwaway rated composites and sandwich panel... not a big deal... one and done.
Long-term space rated composites and sandwich panels are a VERY big deal. Long-term space exposure is hard on all materials... especially composites... and especially in planetary orbit.
Check NASA publications libraries.
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
