Issue:Solidworks Drawing Edge Selection
Chocolate_chimmy
Having an issue in a solidworks drawing. I have a 2° draft in an extrusion. In the drawing file, I need to callout this draft angle, but the software won't select the edge. I'm trying to avoid just drawing another line over it and selecting those edges. When there is not draft, I can select the edge no problem. If anyone knows anyway to help, that would be very appreciated.
Maybe the edge is not straight. Try to do a test using a simple model.
Best regards,
Alex
Make sure your view is activated.
Try right-click over edge, select other.
Chris, CSWP
SolidWorks
ctophers home
Try to reboot your computer to see if you still have the same issue.
Best regards,
Alex
