OSUCivlEng
I am trying to layout a series of parallel bridges over a creek that is more crooked than a politician. The creek meanders from northwest to southeast with multiple 180 degree U shaped bends, while the road is running east to west.
Given the span lengths, 175' to 300' depending on the bridge, I am looking at 3 and 4 span continuous plate girders for the superstructure. The bends make it a challenge to achieve balanced span lengths (all equal spans or end spans ~75% of center span). Also, I will have to justify my design to other engineers who are not bridge or structural engineers, and one person I have already talked to doesn't understand why you can't just use a smorgasbord of different span lengths for a continuous girder.
I have been able to fit more conventional span configurations such as 185'-185'-185'. I suppose you could try and be non-conventional and use various non-symmetrical span lengths, but I think the girder design would be very inefficient and probably expensive. Has anyone ever encountered a similar situation?
