learning2geotech
- Apr 4, 2019
- 38
Liquid limit tests are required to be performed before and after oven-dried for organic soils; however, ASTM 4318 (Atterberg Limits) does not specify the temperature to dry the soils for the after-oven-dried liquid limit test on organic soils? Is it the typical 110±5 Celsius (to burn off water content in accordance with ASTM 2216)? or 440 Celsius (to burn off the organics in accordance with ASTM 2974)?
