joellapointe1717
I'm working on an opensource project about a slr camera. The distance between the film surface and the lens flange is named "flange focal distance". I'm not an optical engineer. So I want to know about optical precision of this "flange focal distance" (machining tolerances). Furthermore, the mirror in these camera is tilted at 45 degrees. This is flipping the optical path towards a ground glass screen. An image is projected on this surface. The precision of the 2 optical paths may be different. Hence, a focused image on the ground glass may not be focused on the film plane.
Is there some technical papers that explains the precision needs for the 2 optical paths?
