Urgent !!!!!! Safe Analysis show Large Enormous displacement values in Ux and Uy direction
Ali Shariff
I am running an analysis for wall foundation and getting huge and very large unrealistic deformation in x and y direction.
Kindly help me if I have made any mistake.
Have you tried turning on 2d plate analysis (Analysis --> Advanced Modelling Options)
you likely only defined a Z value for the soil spring, if relying on friction for stability you'll need to define some minimum value for the x, y springs, otherwise define discrete x,y supports if they exist.
