Use stranded or non stranded (soild cables) for power distribution cables?
Redskinsdb21
Mining
May 4, 2009
45
Also, use the same for ground cable?
Redskin,
you should know by now that you really need to supply a bit more information for this and your other queries such as:
Regulations being used
Domestic or industrial
Power being transmitted
Voltage
Your ole in this
Contractor or designer
etc
Weĺl if you want to use solid cables larger than #10 AWG or possibly #8AWG you may need a special construction sich as Mineral Insulated cable.
In the absence of dpecial conditions Orth American codes do not care.
Ohm's law
Not just a good idea;
It's the LAW!
