TTTKAO
Mining
- Aug 24, 2022
- 79
Hello All,
I am preparing for a test method spec for Concrete-filled Pipe Pile, the pipe pile will be driven to the top level of rock firstly, and then drill soil into the rock 3m further and fill the reinforced concrete. The pipe pile need sharing resistant load with reinforced concrete core pile. i have a few items wondering could get some advice and experience sharing from you.
1. is the static load test necessary? it seems PDA is a trend for the test which can save time and cost for client. i can't find any code or specification stating the static load test is a must for composite pile. wondering what you did before for the similar situation.
2. for PDA test, is it necessary to do the pipe pile test and concrete core pile test separately? or PDA can do one-time test for this composite pile ? i didn't find clear answer on ASTM D4945, but from my understanding PDA can take one time test for the composite pile
3. if PDA is required, is integrity test for concrete core pile still required as well?
4. For tension capacity and lateral capacity test? is this commonly required on piling project, I designed a few piling foundations before, never required this test.
Thank you!
Thank you!
