Navid.Nik
- Nov 25, 2020
- 18
I have a question regarding the bolt tightening in the freezing condition. The connections are not slip critical, so the bolts in the steel structure is going to be snug tight, but the construction is located in an area that is going to be a freezer. Should the bolt tightening to be checked again after the temperature has dropped (around -25 Celsius)?
