Hi, may i know if anybody encounter
Kok Ming Lee
1
Hi, may i know if anybody encounter during maintenance and overhaul of multi stage centrifugal compressor, the bullgear float clearance without mounting cover measurement is within tolerance limits. After installation of mounting cover and torqued all mounting bolts check again the bullgear float clearance is over limit by 0.2mm.
