Importing PDF to DWG
DennisR4
88
Previously, when I would insert a PDF in AutoCAD, I would get a nice clean conversion, with everything editable:
All the lines were clean and sharp. Recently when I try to Import a PDF it converts like this:
And the lines are not sharp:
We did switch from Adobe to Nitro a while back, but have tried different files on different machines, and keep having the same problem. Doesn't seem to matter if I use Adobe, Nitro, or Microsoft print to PDF. Of the last 10 or so PDFs I have imported, one was actually usable.
Also, I know if a scanned PDF is imported, it won't convert correctly. I have this problem with PDFs that aren't scanned, so I don't believe that to be the problem. Anyone else having this issue, or something similar? Thanks in advance!!!
I have a program called Pdf2cad that works quite well. As a side effect, if you use it on a redacted *.pdf file, it will often remove the redacting. It is by VisualIntegrity. It even breaks the drawings down into drawing layers. If it cannot convert the data, it will produce a graphics image of the drawing. Can you attach a bit of a dwg file and I'll give it a try?
