ZStrick
- May 13, 2024
- 1
I am trying to model ribs similar to those shown in the attached picture. The rib tool functionality seems to be limited here as all the ribs are the same height from their respective surface, not all meeting on some imaginary plane. Creating planes offset each surface leaves bad match-ups between ribs at each corner and does not work on the curved surfaces. I have also tried variable pull direction drafts from a projected grid and then thickened them, but this method is finicky, tedious, and sometimes does not work. Is there a functionality built into ribs that I am unaware of or another way to do this efficiently in Creo 3? Thank you!
