Hi guys I am doing Project on Aeroe
Manu_12
Aerospace
May 14, 2024
5
Hi guys I am doing Project on Aeroelastic analysis of pazi wing with pylons , I have attached pylons on fem model of pazi wing by using rbe2s and at independent I have applied conm2 command to attach mass . Whenever I IMPORT BACK THE BDF FILE the mpcs are not read but the triangular mass pops up out there Where i put the mass by using Conm2
Do you mean that you are importing a BDF into Patran (or a similar pre/post processor)?
does your translator program (between your FEM and NASTRAN) understand the CONM2 properly ?
THANKS GUYS FOR UR RESPONSE , I was trying to attach conm2 using NASTRAN bdf but now I have solved this by using patran mass attachment command . it shows and mass is attached
but now I am facing some other error related to splines whenever I try to solve this using aeroelastic solver
