catalina29
Aerospace
I'm trying to run a SOL400 modal (or normal modes) analysis using Nastran 2017. I have two deformable bodies with touching contact between them. The analysis ignores the tuching contact and the two bodies go through eachother.
I did try the same analysis but wit glue contact and it seems to be working and the bodies are moving together, but the glue does not reflect the reality.
Is there a setting that I should make that would help Nastran remember the contact?
I attached the .bdf file.
Thaks!
Thaks!
