Abaqus uses ALE to run only one audit
GaoH
Student
Mar 28, 2024
5
After using ALE in abaqus, multi-core operation is set up, but the result is that only a single core is running, and other cores are not running.
Which version of Abaqus are you using ? Is it Abaqus/Standard or Explicit analysis ? Any warning messages ?
Used in both 2020 and 2023 versions, it is explicit dynamics,and no errors.
