Cryogenic Valves
Mech-Engineer
4
Wondering if anyone can suggest a good valve selection handbook or guidance on selection of cryogenic valves?
Specifically looking at cryogenic on-off valves in sizes 8” and above and pressure classes 300# to 1500#.
Interested in user experience with globe, ball and butterfly valves at these sizes and pressure classes and understanding of industry trends & norms, in terms of optimising performance and cost.
Any advice and tips appreciated.
You can refer to the following standards:
MSS SP-134
[ul]
[li]Valves for Cryogenic Service Including Requirements for Body/Bonnet Extensions[/li]
[li]Specifies requirements for extended bonnet lengths.[/li]
[li]Outlines measures to prevent abnormal pressure build-up.[/li]
[li]Specifies testing procedures including low-temperature tests.[/li]
[/ul]
BS 6364
[ul]
[li]Specification For Valves For Cryogenic Service[/li]
[li]Details requirements for extended bonnet lengths and operation angles.[/li]
[li]Outlines testing procedures and material specifications.[/li]
[/ul]
SHELL MESC SP 77
[ul]
[li]Valves in Low Temperature and Cryogenic Services[/li]
[li]Specifies requirements for extended bonnet lengths and operating angles.[/li]
[li]Outlines sealing, bolting, and inspection requirements.[/li]
[/ul]
The content comes from:Cryogenic Valves
Cryogenic at that pressure??
Why?
The whole point of cryo is to operate at low pressure.
