This is probably a pretty fundamental question, but it is not one I have had to address before.
I'm a geotechnical engineer working on a project for which the structural engineer has requested an effective peak velocity-related coefficient (Av). The project is located near Birmingham, Alabama and is being designed per the 1999 Standard Building Code. The code contains contour maps of the coefficient; however, the seismic hazard information has been recently updated, and the only information I seem to be able to find is the probablistic ground motion (%g). Can I use this information to determine the coefficient Av?
Thanks.
Thanks.
