Mtu ecu 8 troubleshooting
Mohsen kent
1
There is a mtu diesel engine with ecu 8-06
There are 4 fault
610
611
616
472
610 fault is AL Wiring Suction Restrictor 1
611 fault is AL Wiring Suction Restrictor 2
472 shutdown by sensor defect
I don’t know witch sensor doesn’t work well!
And engine doesn’t run
Common rail fuel injection systems sometimes utilize suction control valves as a method of controlling rail pressure.
