Med Che
New member
- Oct 21, 2023
- 8
I'm working on a project in CATIA V5 where I need to use VBA to retrieve the text value associated with a dimension created using Functional Tolerancing & Annotation (FTA). I've attached a screenshot indicating the specific dimension and the associated text value I want to retrieve.
Can anyone guide me on which VBA method or property I can use to access the "Text Associated" value for a dimension created with FTA?
Thank you in advance for your help
