iam42
Industrial
- Feb 15, 2007
- 175
I have just completed a PQR for Super Duplex (S23750) using ER2594 GTAW wire, 100% Nitrogen backing gas and 100% Argon shielding.
Test coupon - 10" Pipe x 0.30" thk
The test results were good and shown below:
Tensile: 119,800 & 120,700 psi
Charpy Average @ -50°C: WM 119 ftlb, FL 76 ftlb, FL+2 90 ftlb, FL+5 134 ftlb, Base 130 ftlb (Subsize: .276" x .394")
Face & Root bends acceptable
Ferrite point count: HAZ Root 43.75, HAZ Cap 56.25, Weld Root 44.5, Weld Cap 56.13,
No evidence of Intermetallic phase
ASTM G48 A: No evidence of pitting, Weight loss 0.2746 g/m2
Hardness: Max Value 319 HV10 (weld metal root)
Now the problem I am seeing is with the Nitrogen level in the chemical analysis.
C: 0.012 Mn: 0.41 P: 0.017 S: <.001 Si: 0.40 Cr: 24.8 Mo: 4.00 Ni: 9.1 Cu: 0.06 N: 0.15
Base Metal N content = 0.2752
Weld Wire N Content = 0.25
Can someone help me understand why it is so low?
