jkimmerling
Computer
- Jun 8, 2024
- 1
Hello all, I have a project where one room, with 6" concrete walls, is going to get a concrete roof.
The open area that the concrete roof will need to span is 13'-4" x 20'-4". Metal decking will be used for the pour, but also as added support, The ribs are 1.5" in depth. Ideally this will be done using #4 (1/2" rebar).
I need to know if it is possible to do this without adding in metal support beams under it. I cannot seem to find a way to calculate allowable/safe spans for concrete roofs.
Thanks in advance
Thanks in advance
