Need help with increasing poly count of 3D model
Channo
16
Hello all,
Recently, my organization is trying to make a animation video of our products to be in our website.
The guy who does animations is asking for 3D model with a high poly count(4 faces). He says that the model I've provided is only triangulated(3 faces).
Is there any way to change my models to high poly count?
I made the original model as .sldprt.
Then converted that to .stp and then to .obj
STEP and other 3D model types like Parasolid, IGES, and ACIS you cannot make changes like that too.
Honestly, I do not see any way to save a SW part\assembly file to an .obj file type.
Have you tried saving to an STL? You can adjust the options for that file type
Scott Baugh, CSWP [pc2]
Mechanical Engineer
Ciholas
"If it's not broke, Don't fix it!"
faq731-376
I haven't tried .stl. Will try that now. Is there any way change to quad obj?
.stl is triangles only.
All solutions to this problem seem to require some task specific software; there are many claiming to do this job turned up in on-line searches.
Most downstream users want a low polygon count; animation software usually comes with subdivision surfacing that allows smoothing of surfaces from lower polygon geometry and can be applied on sub-regions.
What software is the animator using?
@3DDave
He uses blender to create the animations.
@ctopher
Hey! Thanks for the link. I've gone through it and found that the stl files also convert to triangulated models as @3DDave pointed out.
My problem is to convert these triangulated model to a quad model.
Thanks for the help!
 https://files.engineering.com/getfile.aspx?folder=7e3d4e43-78dc-46cc-9dc1-5e1b53ad109c&file=Screenshot_20240611-213301_Edge.jpg
I do have a soft spot for Blender. Rescued from oblivion, it started out as a proprietary product and was going to be put into the trash. A search should turn up the amazing behind-the-scenes history.
Blender has no trouble with triangles. I'm a bit confused as to why that would be a problem. See for import capabilities.
One trouble that anything but triangles can get into is ending up with non-planar polygons which won't break Blender, but may not render correctly. Blender certainly supports subdivision operators.
