CATVBA to get Links of Document
Jegsaran
Automotive
IN
Good day to everyone!!
I am using Catia V5, for one of my project I need to get the link type of all elements in the links of document window as shown in the below snip.
I'm able to get the linktype for elements where pointed document is there using the below code.
But for items which doesn't have pointed documents, I'm unable to fetch the data.
Code:
    Dim stiEngine As stiEngine
    Dim stiDbItem As stiDbItem
    Dim StiChildren As Object
    Dim S As String
    Set stiEngine = CATIA.GetItem("CAIEngine")
    Set stiDbItem = stiEngine.GetStiDBItemFromAnyObject(partDoc)
    Set StiChildren = stiDbItem.GetChildren()
    For i = 1 To StiChildren.count
        Dim linkType 'As CATBSTR
        linkType = StiChildren.linkType(i)
        S = StiChildren.Item(i).GetDocumentFullPath()
        Debug.Print "Attribute Link " & i & ": " & linkType & "Path: " & S
    Next i
Any help on this is highly appreaciated.
Thanks in advance.
Hi Jegsaran-San.
Here is a VBA sample, but it is for VBA 32-bit, so you will need to modify it for 64-bit.
Link
