Pavan Kumar
Chemical
Hi All,
I am sizing a pump for 93% sulfuric acid service. From Narfalco Sulfuric Acid handbook I got the density, viscosity a 15 Deg C (pumping temperature) as 1.8331 gm/cm3 and 25 cP. The vapor pressure is 0.3 mm of Hg at 15 Deg C. The flow is 0.5 gpm with 1/2" Sch 80 line size. The flow is laminar.
My questions are
1. Can I consider 93% Sulfuric Acid as Newtonian?. If yes the Darcy Weisbach equation can be used to calculate head loss with friction factor calculated for laminar flow? I will use Darby-s 3-K method. I wanted to confirm.
2. If it is Non-Newtonian can I use Power Law method. If so where can I get the K and n values for the Power Law Equation Tau = K (du/dy)^n.
Thanks and Regards,
Pavan Kumar
My questions are
Thanks and Regards,
Pavan Kumar
