lLouie
Student
- Jun 19, 2024
- 68
I want to conduct a fatigue test on an aircraft wing. I have performed a fatigue analysis with random loads applied to the wing. Additionally, the loads on the wing have a maximum of 1.2g in the positive direction and 0.4g in the negative direction. How should I determine the loads for the wing? Should I consider the maximum loads it experiences? or Should I use rainflow counting to determine how many times it has been subjected to different loads and then perform the test accordingly?
Sincerely,
Sincerely,
