Inventor 2024 pro: import step issue
o0omirkoo0o
Industrial
Mar 29, 2020
10
Hi everyone.
I'm trying to import a step using open command.
I've tried every single settings available into open dialog box, but i always get the result showed in the attachment.
Parts are greyed out, not visible in 3D area.
How can i fix this?
Thanks for your support :)
 https://files.engineering.com/getfile.aspx?folder=ba44e606-c725-47c4-a555-d38f3fdbf4c9&file=import_step_result.png
I pulled it into Creo and all of the components were on a layer called '200' and that layer was turned off. Not sure how to explore that in Inventor but I hope that helps.
David
Hi.
Yes i did it already and i noticed the same. Problem.is that i dont know how make them visoble without open them one by one into inventor...
