Doubt in the represntation of the PID Controllers in P&ID diagram
ritesh bindal
Chemical
Jul 8, 2017
1
Hello All,
i have attached a file in which there are queries pertaining to the depiction of PID (Proportional, Integral, Derivative) Controllers in the P&ID diagram. Request the members to kindly see the file attached & provide the resolution of my query. i cant attach the snips from the P&ID because of the confidentiality.
with regards,
Ritesh
 https://files.engineering.com/getfile.aspx?folder=5eb6e7e2-4178-47cd-9e5d-229afe606896&file=doubts_in_controller_symbols.pdf
OP,
I am not going to recommend literature but instead a visit to your local power plant. The horizontal line represents board or panel mounted. Think of a control room with hundreds of gages mounted on a geometric/process flow driven board or wall so operators can monitor the process. These are physical instruments, dials, gauges, knobs, analog control devices. No horizonal line = local device, so on a P&ID a circle on a line represents an instrument at that or approximate to that point. Next topic will be what happens when you put a box or diamond around the circle and what type of interconnecting lines are shown.
