sjohns4
- Sep 14, 2006
- 123
I'm looking to possibly re-cover and re-use some 25 & 50 kVA single phase distribution transformers. We're a primary power customer on a 13.2kV / 7.6 kV system. The transformers are name plate 13200GRDY / 7600 HV and have 2x2.5% taps over and below nameplate. By my math, with the tap changer at the extremes the transformers would be suitable for 7220 Volt to 7980 Volt, so assuming the system was running pretty close to nominal voltage, could these same transformers be used on a 12470/7200 or 13800/7970 primary system?
If it'll work, how likely is it anyone will care (i.e. utility, inspectors, etc.)?
I usually live on the secondary side of transformers and this, to me, sounds like a 208V vs 240V thing.
I'm asking because I have no idea what part of the country or who's system we'll be connected to next.
Mike
